plus de multiboot windows/zorin depuis l'activation du secure boot dans le bios ??????
tolunq
Nb de « J’aime » reçus: 4
Message par tolunq »
resultat :
j'ai bien mis menu à la place de hidden :
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`( . /etc/os-release; echo ${NAME:-Ubuntu} ) 2>/dev/null || echo Ubuntu`
GRUB_CMDLINE_LINUX=""
# If your computer has multiple operating systems installed, then you
# probably want to run os-prober. However, if your computer is a host
# for guest OSes installed via LVM or raw disk devices, running
# os-prober can cause damage to those guest OSes as it mounts
# filesystems to look for things.
#GRUB_DISABLE_OS_PROBER=false
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
GRUB_THEME=/usr/share/grub/themes/zorin/theme.txt
GRUB_DISABLE_MEMTEST=true
ensuite avec le terminal j'ai bien rentré la ligne de code suivante :
gnome-text-editor 2> /dev/null admin:///etc/default/grub
puis celle-ci :
sudo update-grub
puis redemarrage du pc ... et toujours pareil... lancement de zorin sans passer par la case multiboot ! damned !
Extrait du manuel de GRUB — remets sur "hidden" (sans oublier "sudo update-grub"), tu as trois touches à essayer au démarrage :
GRUB_TIMEOUT_STYLE
Si cette option n'est pas définie ou définie sur ‘menu’, alors GRUB affichera le menu puis attendra que le délai d'attente défini par ‘GRUB_TIMEOUT’ expire avant de démarrer l'entrée par défaut. Appuyer sur une touche interrompt le délai d'attente.
Si cette option est définie sur ‘countdown’ ou ‘hidden’, GRUB attendra que le délai d'attente défini par ‘GRUB_TIMEOUT’ expire avant d'afficher le menu. Si ESC ou F4 sont pressés, ou Maj est maintenu enfoncé pendant ce temps, il affichera le menu et attendra la saisie.
J'attends ton retour pour te faire une dernière proposition (honnête, bien sûr).
tolunq
remis sur hidden puis sudo update-grub...
redémarrage avec appui ou "tapotage" sur la touche maj (droite ou gauche) ou esc ou f4...
a chaque redémarrage, une touche différente.
à chaque fois l'écran se bloque sur le logo Lenovo ou sur un écran noir...
pour l'appui sur esc, ça donne cet écran :
et ça se fige ... et après appui sur une touche, soit c'est figé sur l'écran logo 'lenovo' soit sur un écran noir... et ça ne bouge plus.
si je redémarre en appuyant sur aucune touche... ça lance zorin mais c'est devenu très très long à avoir le bureau de zorin
Merci pour les essais et le retour !
La photo confirme ce que je pense de cet ordinateur : un second dispositif de sécurité semble doubler celui de Windows.
Pour ce qui est du délai, comme rien n'a été modifié, ça passera.
Si tu veux d'autres propositions, envoie-moi un MP.
tolunq
Oh oui j'en veux... je veux retrouver mon multiboot.
tolunq
je viens de voir un truc sur le site malekal au sujet du multiboot :
https://www.malekal.com/grub-reparer-du ... indows-10/
en faisant le commande : sudo efibootmgr -v
ce que j'ai fait et j'ai ceci :
tolunq@tolunq-ThinkPad-L540:~$ sudo efibootmgr -v
[sudo] Mot de passe de tolunq :
BootCurrent: 0014
Timeout: 2 seconds
BootOrder: 0014,0015,0000,0001,0002,0003,000A,0007,0008,0009,000B,000C,000D,0012
Boot0000  Setup	FvFile(721c8b66-426c-4e86-8e99-3457c46ab0b9)
      dp: 04 06 14 00 66 8b 1c 72 6c 42 86 4e 8e 99 34 57 c4 6a b0 b9 / 7f ff 04 00
Boot0001  Boot Menu	FvFile(126a762d-5758-4fca-8531-201a7f57f850)
      dp: 04 06 14 00 2d 76 6a 12 58 57 ca 4f 85 31 20 1a 7f 57 f8 50 / 7f ff 04 00
Boot0002  Diagnostic Splash Screen	FvFile(a7d8d9a6-6ab0-4aeb-ad9d-163e59a7a380)
      dp: 04 06 14 00 a6 d9 d8 a7 b0 6a eb 4a ad 9d 16 3e 59 a7 a3 80 / 7f ff 04 00
Boot0003  Lenovo Diagnostics	FvFile(3f7e615b-0d45-4f80-88dc-26b234958560)
      dp: 04 06 14 00 5b 61 7e 3f 45 0d 80 4f 88 dc 26 b2 34 95 85 60 / 7f ff 04 00
Boot0004  Startup Interrupt Menu	FvFile(f46ee6f4-4785-43a3-923d-7f786c3c8479)
      dp: 04 06 14 00 f4 e6 6e f4 85 47 a3 43 92 3d 7f 78 6c 3c 84 79 / 7f ff 04 00
Boot0005  Rescue and Recovery	FvFile(665d3f60-ad3e-4cad-8e26-db46eee9f1b5)
      dp: 04 06 14 00 60 3f 5d 66 3e ad ad 4c 8e 26 db 46 ee e9 f1 b5 / 7f ff 04 00
Boot0006  MEBx Hot Key	FvFile(ac6fd56a-3d41-4efd-a1b9-870293811a28)
      dp: 04 06 14 00 6a d5 6f ac 41 3d fd 4e a1 b9 87 02 93 81 1a 28 / 7f ff 04 00
Boot0007* USB CD	VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,86701296aa5a7848b66cd49dd3ba6a55)
      dp: 03 0a 24 00 d2 38 78 bc 82 0f 60 4d 83 16 c0 68 ee 79 d2 5b 86 70 12 96 aa 5a 78 48 b6 6c d4 9d d3 ba 6a 55 / 7f ff 04 00
Boot0008* USB FDD	VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,6ff015a28830b543a8b8641009461e49)
      dp: 03 0a 24 00 d2 38 78 bc 82 0f 60 4d 83 16 c0 68 ee 79 d2 5b 6f f0 15 a2 88 30 b5 43 a8 b8 64 10 09 46 1e 49 / 7f ff 04 00
Boot0009* ATAPI CD0	VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,aea2090adfde214e8b3a5e471856a35400)
      dp: 03 0a 25 00 d2 38 78 bc 82 0f 60 4d 83 16 c0 68 ee 79 d2 5b ae a2 09 0a df de 21 4e 8b 3a 5e 47 18 56 a3 54 00 / 7f ff 04 00
Boot000A* ATA HDD0	VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f604)
      dp: 03 0a 25 00 d2 38 78 bc 82 0f 60 4d 83 16 c0 68 ee 79 d2 5b 91 af 62 59 56 44 9f 41 a7 b9 1f 4f 89 2a b0 f6 04 / 7f ff 04 00
Boot000B* ATA HDD1	VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f605)
      dp: 03 0a 25 00 d2 38 78 bc 82 0f 60 4d 83 16 c0 68 ee 79 d2 5b 91 af 62 59 56 44 9f 41 a7 b9 1f 4f 89 2a b0 f6 05 / 7f ff 04 00
Boot000C* USB HDD	VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,33e821aaaf33bc4789bd419f88c50803)
      dp: 03 0a 24 00 d2 38 78 bc 82 0f 60 4d 83 16 c0 68 ee 79 d2 5b 33 e8 21 aa af 33 bc 47 89 bd 41 9f 88 c5 08 03 / 7f ff 04 00
Boot000D* PCI LAN	VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,78a84aaf2b2afc4ea79cf5cc8f3d3803)
      dp: 03 0a 24 00 d2 38 78 bc 82 0f 60 4d 83 16 c0 68 ee 79 d2 5b 78 a8 4a af 2b 2a fc 4e a7 9c f5 cc 8f 3d 38 03 / 7f ff 04 00
Boot000E* IDER BOOT CDROM	PciRoot(0x0)/Pci(0x16,0x2)/Ata(0,1,0)
      dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 02 16 / 03 01 08 00 00 01 00 00 / 7f ff 04 00
Boot000F* IDER BOOT Floppy	PciRoot(0x0)/Pci(0x16,0x2)/Ata(0,0,0)
      dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 02 16 / 03 01 08 00 00 00 00 00 / 7f ff 04 00
Boot0010* ATA HDD	VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f6)
      dp: 03 0a 24 00 d2 38 78 bc 82 0f 60 4d 83 16 c0 68 ee 79 d2 5b 91 af 62 59 56 44 9f 41 a7 b9 1f 4f 89 2a b0 f6 / 7f ff 04 00
Boot0011* ATAPI CD	VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,aea2090adfde214e8b3a5e471856a354)
      dp: 03 0a 24 00 d2 38 78 bc 82 0f 60 4d 83 16 c0 68 ee 79 d2 5b ae a2 09 0a df de 21 4e 8b 3a 5e 47 18 56 a3 54 / 7f ff 04 00
Boot0012* PCI LAN	VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,78a84aaf2b2afc4ea79cf5cc8f3d3803)
Boot0014* Zorin OS	HD(1,GPT,9e070e54-2296-4475-aa84-2c58621a4def,0x800,0x66668)/File(\EFI\ubuntu\shimx64.efi)
      dp: 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 68 66 06 00 00 00 00 00 54 0e 07 9e 96 22 75 44 aa 84 2c 58 62 1a 4d ef 02 02 / 04 04 34 00 5c 00 45 00 46 00 49 00 5c 00 75 00 62 00 75 00 6e 00 74 00 75 00 5c 00 73 00 68 00 69 00 6d 00 78 00 36 00 34 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
Boot0015  Windows Boot Manager	HD(1,GPT,9e070e54-2296-4475-aa84-2c58621a4def,0x800,0x66668)/File(\EFI\Microsoft\Boot\bootmgfw.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d000000ffff0100000010000000040000007fff0400
      dp: 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 68 66 06 00 00 00 00 00 54 0e 07 9e 96 22 75 44 aa 84 2c 58 62 1a 4d ef 02 02 / 04 04 46 00 5c 00 45 00 46 00 49 00 5c 00 4d 00 69 00 63 00 72 00 6f 00 73 00 6f 00 66 00 74 00 5c 00 42 00 6f 00 6f 00 74 00 5c 00 62 00 6f 00 6f 00 74 00 6d 00 67 00 66 00 77 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
    data: 57 49 4e 44 4f 57 53 00 01 00 00 00 88 00 00 00 78 00 00 00 42 00 43 00 44 00 4f 00 42 00 4a 00 45 00 43 00 54 00 3d 00 7b 00 39 00 64 00 65 00 61 00 38 00 36 00 32 00 63 00 2d 00 35 00 63 00 64 00 64 00 2d 00 34 00 65 00 37 00 30 00 2d 00 61 00 63 00 63 00 31 00 2d 00 66 00 33 00 32 00 62 00 33 00 34 00 34 00 64 00 34 00 37 00 39 00 35 00 7d 00 00 00 ff ff 01 00 00 00 10 00 00 00 04 00 00 00 7f ff 04 00
en time out je n'ai que 2 secondes. je croyais que c'était 10.
en bootOrder: 0014,0015,0000,0001,0002,0003,000A,0007,0008,0009,000B,000C,000D,0012
visiblement 0014 c'est zorin et 0015 c'est le windows boot manager.
et si on inversait ? l'ordre comme ils le disent dans l'article de malekal ?
Message n° 27
Désolé, j'ai traité tellement de problèmes du même ordre ces derniers mois que je ne sais plus ce que j'ai dit à qui.
Mais tu m'as déjà envoyé le retour d'efibootmgr que je t'avais demandé. L'option "verbose" n'apporte rien de plus que de l’illisibilité et je t'ai déjà fait l'interprétation.
Pour le délai, je l'avais déjà vu, c'est celui du BIOS, autrement dit, du lancement de l'ordi. Celui de GRUB, c'est celui du lancement de l'OS à partir de l'affichage du menu de démarrage (ou pas).
Si tu as un menu de démarrage sur Windows, explique moi, je ne sais pas : il y avait W11 sur mon portable, mais je ne m'en sers pas — mais je pourrais donner des conseils pour le réinstaller à ceux qui ont bêtement formaté la partition EFI comme je l'ai fait récemment.
Sinon, tu démarreras sur Windows au lieu de Zorin...
tolunq
Message n° 28
j'en ai marre ... fatigué .. j'y comprends plus rien...
j'ai démarré mille fois .... j'ai eu 1 fois à l'instant le multiboot mais écrit en tout petit à l'écran...
j'ai réessayé mais terminé ! il n'apparait plus.
j'ai remis secure boot sur disabled pour avoir windows...
je crois que je vais désinstaller zorin et le réinstaller depuis windows mais le secure boot sur enable. on verra bien.
Il faut que je désinstalle comment zorin pour ne pas faire + de dégats ?
Il est installé sur un ssd de 1 T partitionné comme suit :
- win 10
- win 7
- data 1
- data 2
et une dernière partition pour zorin de 150 go
Message n° 29
Il n'y a juste à prendre un peu de recul, et faire ça par MP, comme nous avons commencé à le faire.
Je reviendrai faire une synthèse quand ce sera fini.
Mais je ne sais pas pourquoi, j'ai un peu l'impression que tu es du genre à te lancer tête baissée. 🤨
Je décline toute responsabilité si ça ne marche pas.
tolunq
Message n° 30
non non, tu te trompes... je ne suis pas tête baissée.
avant de revenir sur le forum pour exploser mon pb, j'ai feuilleté tout ce que j'ai pu sur le net sur les pb de multiboot avec win et linux... et il y en a...
j'ai essayé des lignes de code sans rien que cela change.
je suis donc revenu sur le forum car je savais que tu serais là :)
en décembre tu m'avais déjà beaucoup aidé pour mettre au point ce multiboot (on ne voyait pas le multiboot windows avec choix win 7 et win 10) et cela avait fonctionné
Il y a quelque chose dans le bios qui me remet à chaque fois zorin en 1er boot ... damned !
